PCB511
Mar 17, 2017Aspirant
How to setup 2 AC750 (EX3700) extenders for 5 Ghz
I'm having a difficult time setting up 2 seperate, AC750 Extenders. Using Arris TG862G modem (from cable company) Uses WPA2-PSK I followed the instructions and it keeps failing for the 2nd o...
PCB511
Mar 21, 2017Aspirant
I tried both doing both at the same time. (that didn't work)
I tried doing the 2nd, while 1st one was on (that didn't work)
I did the 2nd one, with the 1st one off and using the same SSID (that didn't work)
I did the 2nd one, with the 1st one off and created a new SSID (that worked)
However, now I have 2 additional SSID (for a total of 4 SSID)
Extender1 - name1_2GEXT and _5GEXT
Extender2 - name2_2GEXT and _5GEXT
name1_2GEXT and name2_2GEXT use the same channels
name1_5GEXT and name2_5GEXT use the same channels
Is there a way to get both extenders to use the same name?
DarrenM
Mar 22, 2017Sr. NETGEAR Moderator
Hello PCB511
You can have them both named the same but it is not recommend as it could cause issues.
DarrenM
