specialk3117
Apr 24, 2018Aspirant
How to setup 2 AC750 (EX3700) extenders
I have two AC750 (EX3700) extenders which are both connected to my ASUS RT-AC3200 router. The extenders work fine with default settings. But if I configure fast lane, where both extenders connect to...
specialk3117
After some additional research, it seems that my router may need a setting changed. Whichever extender connects first to router on same band, then that extender wins and gives access, the other extender never gets an ip. Two extenders on different bands works fine (ie 2.4 and 5ghz) but same band conflict. What needs to be done to fix this?
DarrenM
Apr 26, 2018Sr. NETGEAR Moderator
Have you tried to reserve the IP address of the extenders in the routers settings?
DarrenM
