radumaz's avatar
radumaz
Initiate
Nov 19, 2022
How to use EX7000 as a switch?
After reconfiguring my local network I have an unused EX7000. Can I use it as an ethernet switch (only wired, no wifi) ? Are there any specific ports for in and out?
    • radumaz's avatar
      radumaz
      Initiate
      Thanks. What about the wired connection speed in switch configuration? Does it go over 100Mbps? There are no specs for this configuration. My gateway/network is capable of 400Mbps.
      • plemans's avatar
        The EX7000 has gigabit ports. If they're only connecting at 100mbps speeds, check your cables.
        Move the ex7000 right next to the router and connect it with 2 known good 6ft cables (one from router--extender and other from extender---device) and test the speeds.
