lowepn
Dec 28, 2018Aspirant
How to use PL1000v2 as a WiFi repeater
IS IT POSSIBLE TO USE THE POWERLINE WIFI PL1000V2 AS A WIFI REPEATER AND MOVE THROUGH THE HOUSE/YARD AND NOT HAVE TO SWITCH SSIDS AS I GET FURTHER AWAY FROM THE CENTRAL ROUTER?
- Dec 28, 2018
You can set the PLW1000 to use the same network name as your main router.
You might find that you sometimes need to toggle your wifi on/off in your clients when you move into the PLW1000 coverage area - that depends on how aggressively the clients roam to a stronger network.
Dec 28, 2018Guru - Experienced User
lowepn
Thank-you!
