KMM833
Jul 24, 2022Aspirant
How to view configuration of Netgear EX6150v2
I am trying to connect a Netgear EX6150v2 and having trouble (Windows 10). I see the 2GT and 5GT but they can't connect. I suspect I made a mistake in the configuration but don't know how to view the...
michaelkenward
Jul 24, 2022Guru - Experienced User
What happens when you try?
Connecting how?
"Can't connect" could mean many things. Any error messages of any sort?
As this is a wifi extender, perhaps you could tell us what sits in front of it. The router? Modem/gateway?
Is it configured as an access point or an extender?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- KMM833Jul 24, 2022Aspirant
Thank you. I'll check with the community link you provided.
- plemansJul 25, 2022Guru - Experienced User
What router did you connect it to?
What method of setup did you use? The WPS push button method? or using the installation assistant?
If WPS, factory reset the extender by pushing and holding reset for 7-15 seconds. Then install it using the installation assistant.
