swedishengineer
Nov 09, 2015Follower
Humax FVP-4000T - wireless lan connection problems with Netgear modem and extensions
I wonder if you can help I recently bought a HUMAX FVP-4000T Serial No 63710737402483 When following the instructions for WLAN from the Settings menu it always says the 'Network connection fail...
nhann
Nov 09, 2015NETGEAR Employee Retired
Hi swedishengineer,
Can you please verify which NETGEAR Extender you are using?
Other than the Humax, can you try connecting another device/computer to the Extender's WiFi?
Is this your first time setting up the extender?
Peter-k
Dec 09, 2015Aspirant
Hi, I am also having problems with a Netgear router connection. I can only do it wirelessly, the Humax sees the router but when I enter the password it fails to connect. I have tried numerous times so know it is not incorrect password entering. Please could you advise if there is a problem connecting to Netgear routers. Thanks. Peter
- nhannDec 09, 2015NETGEAR Employee Retired
Hi peter-k,
Can you please clarify which Netgear router you have? Is it running the latest firmware?
If you change your Router to have No Security (no password). Will the Humax connect?
