swedishengineer
Nov 09, 2015Follower
Humax FVP-4000T - wireless lan connection problems with Netgear modem and extensions
I wonder if you can help I recently bought a HUMAX FVP-4000T Serial No 63710737402483 When following the instructions for WLAN from the Settings menu it always says the 'Network connection fail...
Peter-k
Dec 09, 2015Aspirant
Hi, I am also having problems with a Netgear router connection. I can only do it wirelessly, the Humax sees the router but when I enter the password it fails to connect. I have tried numerous times so know it is not incorrect password entering. Please could you advise if there is a problem connecting to Netgear routers. Thanks. Peter
nhann
Dec 09, 2015NETGEAR Employee Retired
Hi peter-k,
Can you please clarify which Netgear router you have? Is it running the latest firmware?
If you change your Router to have No Security (no password). Will the Humax connect?
