diva4361
May 06, 2017Follower
I can’t access www.mywifiext.net; what do I do?
I know this seems really tricky, but even though it took me a bit, I got it. What I did was plugged the extender into an outlet close to the router. Then I connected the extender to my computer via a...
hpw2408
Jul 05, 2017Apprentice
I tried hooking the extender by ethernet cable to my network and that would not work to get to www.mywifiext.net. I was going to bring it in this room and hook it straight to the computer when this idea hit me.
Part of the troubleshooting had been to make a static IP address from the router to the extender which has a built in IP address of 192.168.1.250.
I looked by logging into the Netgear Router (not the extender) and looked at "attached devices". It showed that the router had given the extender an address of 192.168.1.3. I then put in 192.168.1.3 into the browser address bar and it took me right to the network extender web page interface.
Then I updated the firmware and the extender restarted and then the browser did not see the extender. I had to then use www.mywifext.net to get to the web page of the extender. Looking at the attached devices in the router showed that now the extender had the address of 192.168.1.250. So it should work fine in the future or if it doesn't then I will just see what the address is of the device and put in the browser address bar.
hpw2408
After my router rebooted I could not get to the extender page. I checked the router and it had given the extender an address of 192.168.1.2
I then put that number in my browser and accessed the extender. Then I went into Settings of the extender and gave it a static address of 192.168.1.250.
So the static address is set on the extender and NOT as a reserved address on the router.
This is similar to the way that I had to set a static address on my HP OfficeJet.
