narich5625
Nov 27, 2018Aspirant
I can’t access www.mywifiext.net
I have a Netgear extender model EX2700, I haven't used it in years but began using it again today. I was able to get the wifi working but when I go to http://www.mywifiext.net/, I get the message
narich5625
Dec 04, 2018Aspirant
Thank you for the quick response. I followed your instructions and unfortunately, they did not work. I am still not able to connect to the network.
Dec 05, 2018Guru - Experienced User
Try resetting the extender (without pressing WPS). Then you should see a wifi network called NETGEAR_EXT. Join that network, and you should be able to browse to http://www.mywifiext.net, and complete the setup.
