Luisosi's avatar
Luisosi
I have a smart samsung tv but fails to connect to the wireless network ex2700
I have a samsung tv but fails to connect to the wireless network ex2700, other devices like tablets and smartphones recognize very well the extender, but TV no, somebody know why?
Thank you
  • Just a guess, but if it's an older TV, it may not support WPA2 security.  You may need to adjust the security settings on your EX2700 to use either WPA+WPA2 or just plain WPA.  Either should work.
  • Thank you, but one day after the TV connect to Netgear correct.
    • VE6CGX's avatar
      VE6CGX
      Master
      What is error message when you try to connect?
  • The message was "Not found internet web".
    But, the day after it connect correctly.
