lexnaughton
Apr 22, 2016Follower
I keep getting 404 - file or directory not found at last hurdle - any ideas? N300
I'm having a hard time trying to get my new wifi extender connected. I'm in the same room as my router and can link all of my devices to the Netgear but as soon as it says 'once you have connected y...
DarrenM
Apr 28, 2016Sr. NETGEAR Moderator
Hello lexnaughton
Are you having issues connecting devices to the extender or connecting the extender to the router or both? If you can not connect the extender to the router have your tried to use WPS.
DarrenM
- JonJoliMay 17, 2016Aspirant
Hello,
I keep getting the exact same issue.
I purchased a Netgear EX2700-100UKS today.
I've tried installing it three times using IE, Chrome and Firefox and at the page where I'm asked to connect my devices to the new _EXT network and tick the box I then get a "404 - File not found" error. I've hard reset the device in between each install attempt and still no success.
All of my devices can see and connect to the _EXT network without issue but none of them can connect to the internet after they've connected to the extended network. The extender shows 4 green lights.
I can't use the WPS option as there isn't a WPS button on my router - a Thomson O2 Wireless Box 3.
This is the first piece of Netgear gear I've ever bought and right now I'm regretting the purchase - it shouldn't be this hard!
Any suggestions gratefully received.
Thanks.
- DarrenMMay 19, 2016Sr. NETGEAR Moderator
Hello jonjoli
Have you tried to change the security type on the router or even remove a password from the router just to test and see if the extender will connect then?
DarrenM
- BelmorkNov 13, 2016Aspirant
Sorry to bump an old post but I'm having the exact same issue. I've tried it multiple times with multiple browsers. I've used my phone as well. I can connect to the router / extender just fine just am unable to finish the setup. It tells me to connect devices and click continue. Once I click continue it gives me a 404 error every time. It's like that page has been deleted. I've tried multiple firmware versions and that hasn't done it either. I dumped it down to the very first firmware and it doesn't give an option to update it before setting it up completely so I'm stuck with the first version now. I've spent a good 8 hours working on this damn thing and don't consider myself stupid when it comes to dealing with router/networking but this one has me stumped. Please for the love of god don't make me have to send this thing back. It's just frustrating.
