A_W's avatar
A_W
I want to return my product/ sell it on
I have a Tri band Wifi Router that I bought from JBHIFI just over 6 months ago and a more recent purchase from Ebay of an Orbi System add on. They are compatable but the system is absolute rubbish and I want to return it if I can. But of course, no actualy person to talk to regarding this, as neither bought directly from Netgear. Can you sell them on? Does this affect the registration? I don't exactly want my name/ details linked to it. It's been too long to return to either and they're so expensive I don't want to just chuck them in the bin. Ideas?
  • plemans's avatar
    We potentially can help get them running better but if you're done with them, you can sell them.
    I'd factory reset the (push and hold reset for 7-15 seconds while powered on).
    That'd clear out your info from them.
    the registration doesn't pass on but warranty isn't transferable so its kind of mute point anyway.
    • A_W's avatar
      A_W
      Thank you for the advise, I will definitely do the reset.
      I highly doubt you can get them to work better, but I appreciate the sentiment.
