CatenaryKid
Jan 16, 2016Tutor
I'd like to sset up my R8500 as a range extender or repeater.
I just swiched my internet from DSL to Verizon Wireless. I have a Novatel T1114 Tasman Verizon Wireless 4G LTE Broadband router which is pretty weak, signal wise. I'd like to know how to connect t...
- Jan 19, 2016
OK, "TheEther" that sort of did it. I can print and scan from all my devices & PC's. I can see the printer from everywhere on the network and vice-versa. I cannot connect the printer to the network using either the router, printer or any of the PC's connection links, but that doesn't really matter, as long as the dang thing works, right? Anyhow, thanks much for the help. Couldn't have done it without you!
TheEther
Jan 16, 2016Guru
Connect the R8500 to your Verizon router via Cat6 cable and enable AP Mode on the R8500. Repeater functionality doesn't work well on Netgear routers.
CatenaryKid
Jan 17, 2016Tutor
OK, I'm going to give that a try. Really looking forward to seeing how the R8500 works, I've heard so much about it! I'll keep you posted.....
