CatenaryKid
Jan 16, 2016Tutor
I'd like to sset up my R8500 as a range extender or repeater.
I just swiched my internet from DSL to Verizon Wireless. I have a Novatel T1114 Tasman Verizon Wireless 4G LTE Broadband router which is pretty weak, signal wise. I'd like to know how to connect t...
- Jan 19, 2016
OK, "TheEther" that sort of did it. I can print and scan from all my devices & PC's. I can see the printer from everywhere on the network and vice-versa. I cannot connect the printer to the network using either the router, printer or any of the PC's connection links, but that doesn't really matter, as long as the dang thing works, right? Anyhow, thanks much for the help. Couldn't have done it without you!
CatenaryKid
Jan 19, 2016Tutor
Yes, I can and did ping it. It is also listed in the Genie's wireless network map, the network SSID is correctly liste on the wireless network summary page of the printer as well, and I can print from it. But I can't use any of the printers other features, like scanning. Yes, I've rebooted everything multiple times.
Any other ideas?
Sorry to be such a pain in the ass...
TheEther
Jan 19, 2016Guru
If you can ping it, then it's not a MAC address filtering problem.
Does scanning work when the printer is connected to the Verizon Wi-Fi network?
- CatenaryKidJan 19, 2016Tutor
Yes it does.
I'm going to try uninstalling/reinstalling the drivers for the printer and see if that helps. If you can think of anything I can try, I'd be grtateful, as I've been for your help thus far. I'm clearly out of my pay grade on this one....but I remain hopeful. Thanks!
