Colveu
Feb 22, 2017Aspirant
Imposible to manage USB sorage
When I try to add or modified a file on my HD on USB storage I receive the following message; Impossible de copier les éléments vers « USB_Storage » parce que vous ne disposez pas de l’autorisati...
DarrenM
Feb 24, 2017Sr. NETGEAR Moderator
Hello colveu
Does this only happen when you use the extenders network or when the extender is on the network.
DarrenM
schumaku
Feb 24, 2017Guru - Experienced User
DarrenM, Reads to me like Colveu does work with the ReadySHARE (USB Disk Share) available on the EX7000.
Would be nice to hear on the operations mode the EX7000 is configured, what storage and file system is in the play, and of this is probably one used more or less heavily before connected direct to a Mac. Especailly HFS/HFS+ non-native drivers tend to fail under some of these conditions.
- ColveuFeb 25, 2017Aspirant
Hello,
THank you for your reply.
My MBP system files is HFS+
I understand that could be the problem ???
- ColveuMar 02, 2017Aspirant
Hi,
To day I tried with a new HD in Fat32.
All is working well
Conclusion HSF+ is not really supported by Netgear products !!!
Best regards to all
- schumakuMar 02, 2017Guru - Experienced User
Colveu wrote:Conclusion HSF+ is not really supported by Netgear products !!!
Thisis not limited to Netgear - all system integrators of these non-native file systems (there are two vendors, but that's not relevant) suffer under some variable conditions on HFS/HFS+ file systems. About what I had mentioned above already.
Thank you again for the feedback.
-Kurt
