obscurans
Oct 02, 2017Follower
Impossible to connect to EX7000 when it is connected to internet
EX7000, with factory defaults and stock firmware. Connected on ethernet to setup as wifi extender. Settings are saved (using a different SSID and password, 5G band disabled), device does its thing, l...
DarrenM
Oct 05, 2017Sr. NETGEAR Moderator
I would suggest contacting support could be a hardware issue with the unit.
http://www.netgear.com/support/contact.aspx
DarrenM
