kieran
Dec 08, 2012Aspirant
Incompatibility between Internet Explorer 9 and WN3000RP installation software
I had trouble (re)connecting my WN3000RP wifi range extender. After many frustrating hours on the helpline one persistent operator realized there is an incompatibility between the installation softwar...
kieran
jmizoguchi wrote: did you use IE compatible mode?
Sorry I don't know what that means...once using firefox the installation was as it should have been, and once installed the device is running properly.
