kieran
Dec 08, 2012Aspirant
Incompatibility between Internet Explorer 9 and WN3000RP installation software
I had trouble (re)connecting my WN3000RP wifi range extender. After many frustrating hours on the helpline one persistent operator realized there is an incompatibility between the installation softwar...
Retired_Member
Dec 09, 2012IE Compatibity mode does not fix the problem. I have the same problem with my WN3000RP and IE9.
Chrome can be used as well. IE9 allows initial configuration but will crash everytime after you hit the "Finished" button or try to login after config.
