kieran
Dec 08, 2012Aspirant
Incompatibility between Internet Explorer 9 and WN3000RP installation software
I had trouble (re)connecting my WN3000RP wifi range extender. After many frustrating hours on the helpline one persistent operator realized there is an incompatibility between the installation softwar...
Retired_Member
Dec 09, 2012Correction: IE9 Compatibility Mode DOES work. Thought I had tried it before, but I guess not. It's a bit tricky to get into it, but can be done.
Much easier to use Chrome or Firefox.
