Leejohnst
Aug 18, 2018Star
Incorrect password netgear extender
I’ve seen this issue posted everywhere but nowhere is the answer...
Recently changed broadband providers and router (Technicolor). Had a netgear extender previously but now it will not connect to ...
Leejohnst
Aug 18, 2018Star
Please can you explain how to do this as I don’t know the difference
Aug 18, 2018Guru - Experienced User
Connect a device to the extender's wifi network (or using an ethernet cable to the extender).
Then browse to mywifiext.net. You'll need to log into the admin ui, and can you'll be able select the router's network and enter it's passphrase there.
If you can't log into the admin ui, follow the instructions on page 31 here: http://www.downloads.netgear.com/files/GDC/EX2700/EX2700_UM_EN.pdf
