Leejohnst
Aug 18, 2018Star
Incorrect password netgear extender
I’ve seen this issue posted everywhere but nowhere is the answer...
Recently changed broadband providers and router (Technicolor). Had a netgear extender previously but now it will not connect to ...
Leejohnst
Aug 19, 2018Star
The extender is connected to the router by wps, I have the green lights on the extender. It’s the extender I cannot connect anything to.
I can see the extender in my WiFi list, but it says ‘incorrect password’ even tho I am entering the same password as the router.
Please see link to someone having the same issue as me. The solution is not working for me tho. I hope this helps...
Aug 19, 2018Guru - Experienced User
Are you saying that you can't find the extender's IP address in your router's attached devices list?
Or that you can't browse to that address when in your browser.
- LeejohnstAug 19, 2018Star
I found the IP Address but I can’t log into this either. Attached is the error message. I just reset my netgear password and still the same error.
- StephenBAug 20, 2018Guru - Experienced User
If you entered the security questions in your initial setup, try clicking on "username & password help". That will bring you to the password recovery screen, which might get you through the login. You could also try admin for the username and password for the password (which are the defaults).
The error in your screenshot is "invalid username" It's possible that this is because of the dash, or maybe the length. Of course if it was mis-typed in the initial setup, that would also result in this error. Hopefully DexterJB can provide some information on the limits.
If the two suggestions above don't work, then I suggest doing the paper-clip reset again, and using a shorter and simpler username. The extender doesn't send email to the address, so it doesn't have to be valid.
