helen2000
Aug 30, 2022Aspirant
Incorrect Wifi Password on N300 WiFi Range Extender Model EX2700
I followed the instruction to connect with WPS (my existed internet is Bell Modem White 4000), and all the lights (Power/WPS/Router) are solid green. And I also checked that there is excellent signal...
- Sep 01, 2022
glad you got it working! you might mark it solved so others aren't still trying to solve it.
helen2000
Aug 31, 2022Aspirant
Thank you! I called customer service technical support with the guidance of reset by using installation assistant, and then make the extender working finally.
Sep 01, 2022Guru - Experienced User
