dw711's avatar
dw711
Initial setup
I am trying to do the initial setup.  My network uses WEP so I was trying the manual setup. I have the solid green power light.  I tried to connect my laptop to the extender.  I found NETGEAR_EXT and was able to connect, but there is no internet connection. So I can't navigate to mywifiext.com.  And if I connect to my home wifi I can't setup the extender.  I even tried leaving the laptop connected the extender and connecting the laptop to the router via a LAN cable and that didn't work either.  Please help.  Thanks.
  • Just before I saw your reply, I tried a factory rest.  After the reset I connected to NETGEAR_EXT, my browser went right to the setup page, and everything worked like a champ.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Are you able to change the network to WPA2?
    DarrenM
    • dw711's avatar
      dw711
