sfallon36
Jul 15, 2016Guide
IP Configuration failure - EX6120 Range Extender
So I have setup my Range Extender, everything seems to be working fine, except I cannot connect on the 5Ghz band. I just get the error report IP Configuration Failure. I'm connecting on an Andro...
DarrenM
Jul 19, 2016Sr. NETGEAR Moderator
Hello sfallon36 and Andreas_1
I have seen that this could be a channel issue I would try changing the channel on the main routers 5ghz to see if the extender will start working.
DarrenM
RomanticTuna
Jul 21, 2016Aspirant
I checked with WiFi Analyser and they are both on the same channel (36) switching the Router to 40. WIll let you know how it goes.
