sfallon36
Jul 15, 2016Guide
IP Configuration failure - EX6120 Range Extender
So I have setup my Range Extender, everything seems to be working fine, except I cannot connect on the 5Ghz band. I just get the error report IP Configuration Failure. I'm connecting on an Andro...
collegementors
Dec 21, 2016Aspirant
My Wifi Range extender was working just fine until I bought an Amazon firestick. When I plugged in the firestick, it wanted me to connect to the internet, and I tried to put in the password for my extended network, but it kept telling me that it was incorrect. So, I went onto www.mywifiext.net and it asked me to set it up again--I went through the steps, put in the password, said that the extended passwords would be the same, and it appeared to complete. However, I can't connect at all.
However, I now cannot use the extended networks on ANY devices--not my computer, iPad, TV (which no longer even recognizes my router, which I did NOTHING to), or anything else. I am told that the password is incorrect for either of the extended networks. Nor can I start over and set it up again because I cannot get onto www.mywifiext.net from Chrome or Safari. I can't see the NETGEAR internal network--not even if connected via ethernet.
Dead in the water. HELLLLLPPPPPP
- Andreas_1Dec 21, 2016Aspirant
Hello.
It really appears that something is wrong with the password.
Did you try to set a different password in your WiFi extender?
Just to be sure the password is not too long or contains strange characters.
Maybe the EX6120 can not handle password of existing WiFi.
- collegementorsDec 21, 2016Aspirant
It had been using the same password--and when I re-set it up, I did the same. For some reason, I can't even see the NETGEAR_EXT ssid anymore...even when plugged into ethernet. So, completely flummoxed. And, of course, I have no more warranty so can't get help from Netgear.
- StephenBDec 21, 2016Guru
Try inserting a paperclip into the factory reset slot, and set everything up from scratch.
