sfallon36
Jul 15, 2016Guide
IP Configuration failure - EX6120 Range Extender
So I have setup my Range Extender, everything seems to be working fine, except I cannot connect on the 5Ghz band. I just get the error report IP Configuration Failure. I'm connecting on an Andro...
collegementors
Dec 21, 2016Aspirant
It had been using the same password--and when I re-set it up, I did the same. For some reason, I can't even see the NETGEAR_EXT ssid anymore...even when plugged into ethernet. So, completely flummoxed. And, of course, I have no more warranty so can't get help from Netgear.
Dec 21, 2016Guru - Experienced User
Try inserting a paperclip into the factory reset slot, and set everything up from scratch.
- collegementorsDec 22, 2016Aspirant
Man, I wish I'd seen this before I paid Netgear to re-set everything up remotely for me. Ah well...will know for next time.
