sfallon36
Jul 15, 2016Guide
IP Configuration failure - EX6120 Range Extender
So I have setup my Range Extender, everything seems to be working fine, except I cannot connect on the 5Ghz band. I just get the error report IP Configuration Failure. I'm connecting on an Andro...
Dec 21, 2016Guru - Experienced User
Try inserting a paperclip into the factory reset slot, and set everything up from scratch.
collegementors
Dec 21, 2016Aspirant
Man, I wish I'd seen this before I paid Netgear to re-set everything up remotely for me. Ah well...will know for next time.
