sfallon36
Jul 15, 2016Guide
IP Configuration failure - EX6120 Range Extender
So I have setup my Range Extender, everything seems to be working fine, except I cannot connect on the 5Ghz band. I just get the error report IP Configuration Failure. I'm connecting on an Andro...
tsheeley
Sep 19, 2017Tutor
Yes, it is nonsense. But, it does work and give you both bands on the ext. I use it for my home office and have almost no problems doing video Hangouts and VOIP calls.
If I remember correctly, I also found typos in the little book that came with it... so are you really surprised that it doesn't work 100% as advertised?
jfmoen
Sep 19, 2017Aspirant
yes it worked. Manual is totally wrong. Watch out for resultant network. On my machine the network was mark public. There is a registry hack to change that. Running WIN 10 Pro 64 bit.
- tsheeleySep 19, 2017Tutor
I had the same issue with the network listing as Public... pretty sure that's a Windows thing tho. It happens all the time when I'm setting up new machines for my work.
If I remember correctly, when I viewed the network in File Explorer it gave the yellow bar asking about changing the type and asking about file/printer sharing.You should be able to make it Private then, without any kind of reg hacks.
- jfmoenSep 19, 2017Aspirant
Thanks, yes you should be able to simply click on network icon and change it from public to private. But maybe with recent update to WIN 10 PRO 64 bit that option change. I was not able to click on network icon. So I found the registry hack for doing it pretty easy... no issues as a result of hack. Here is URL for reg hack:
https://www.addictivetips.com/windows-tips/set-a-network-as-public-or-private-windows-10/
