Aelk799's avatar
Aelk799
Ipad connects to _EXT, but doesn't connect to main network
My ipad was connected to the main network. The first time I switched it to the EXT network, it would connect to the EXT network and now it won't connect to the main network.
It it won't ever connect to the main network, even though it can find it. A fried came over with their iphone, and it was able to connect to the EXT network, but not the main network.
  • Yes,  I tired forgetting the main and the Ext. Still won't connect to the main.  Only connects to the Ext
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Aelk799
    Have you tried to forget the main network or even both then connecting again?
    DarrenM
    • Aelk799's avatar
      Aelk799
      • DarrenM's avatar
        DarrenM
        Aeik799
        You may want and try to rename the extender or the main routers SSID.
        DarrenM
