KelleyT
Oct 12, 2022Aspirant
iPhone issue
I have an iPhone 7 and a Netgear EX 2700 extender. A couple of months ago I ran into a problem where I couldn’t connect my iPhone to the extender because it said the extender was paused. I started to ...
- Oct 13, 2022
Thank you. I believe I have accidentally fixed the issue. I said to Forget the Network on my iPhone, and then reconnected, and all seems to be well. For the time being anyway!
KelleyT
Oct 13, 2022Aspirant
michaelkenward
Oct 13, 2022Guru - Experienced User
It may have been "accidental" but it is actually one of those quick and simple tricks that should be at the top of any list of things to do when you have wifi connection problems. (The wifi equivalent of the "on/off" reboot.)
Pity we didn't suggest it sooner.
Glad it fixed things for you.
