ETaylor10's avatar
ETaylor10
Follower
Jun 20, 2021
Is EX2800 WiFi Range Extender compatible with my NetGear Router model R6120
Is EX2800 WiFi Range Extender compatible with my NetGear Router model R6120.
Do you recommend a different product to get internet service in another room in my home?   Only 1100 sq ft, and I get a very poor internet signal in my dining room, separated from my home office by a hallway.  I am NOT computer savvy.  Please reply as in Dummy 101!  Thank you!
  • plemans's avatar
    Will it work? sure
    Will it make your wifi better? not enough info.
    Reason I say that is a stsandard router should be able to cover 1100sq ft without issues.
    so if you're having issues, then you need to determine why.
    1. is it an intererence issue? try changing the wifi channels you're broadcasting on
    2. is it a materials issue? what I mean is your home made of brick/concrete/adobe/plaster lathe/or some other materials that block wifi? If so, then adding an extender isn't always going to help. It potentially can but it isn't a for sure.
    3. Is it something in the walls blocking wifi? metal hvac is great at blocking wifi. Sometimes moving a router laterally can help with signal propagation.
  • michaelkenward's avatar
    michaelkenward
    No reason why it shouldn't work. Extenders should be able to connect to any router.
    Try plugging your needs into the filters on the product pages:
    WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
    and
    Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
    But given the size of your property, Orbi is probably overkill.
    Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
