hsbridge
Nov 10, 2016Tutor
Is it possible to daisy chain two EX7000s and an R7000 with Cat6?
I'm attempting to extend a Cox cable network from our main house (currently using a wireless R7000) to two outbuildings. I've tried using an EX7000 as a wireless range extender and found the signal s...
TheEther
Nov 10, 2016Guru
Since the daisy chains are wired then, yes, this should work. What is not recommended is to wirelessly connect one EX7000 to another EX7000.
hsbridge
Nov 26, 2016Tutor
Thank you,TheEther, for your positive response. I just wanted to follow up to say that the hard-wired daisy chain of two Ex7000s and the R7000 described in my earlier message worked like a charm and we're very happy with the results. I appreciate your help.
