GH3's avatar
GH3
Is it possible to 'piggyback' a WN3000RP Extender?
Is it possible to 'piggyback' a WN3000RP Extender?  I have several extenders.  Is it possible to use one to extend the range of my WiFi to another extender.  Now I get a solid red light on Router Link LED.
Thanks for any information.
  • Yea you are able to do this but it is not recommend as it can cause issues such as speed and performance issues in your network.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
    • GH3's avatar
      GH3
      Thanks for the info.  Sounds like it may not be worth the effort.
