Orbi135Ward
Jan 03, 2025Aspirant
Is there an extender with external antenna that works with RBR40 router with RBW30 satellites
I have a pole barn for mechanical repair, welding projects, work benches. The building is grounded all metal walls and roof, concrete floor, no windows. I spend a lot of time in this building and w...
- May 18, 2025
Maybe running an ethernet cable from the satellite in my garage to an access point in the pole barn would provide the most reliable wifi service to the pole barn. I have an old Netgear EX6100 that can be used as a hard-wired access point. However, running a wire will be a chore. Drilling through the garage wall, channeling under a concrete sidewalk with a water hose hooked to some 3/4" conduit, coming up through a concrete floor in the lawn shed. Once I get that far I have a conduit from the shed to the pole barn I can run the wire through. It even has a 15 year old chalk line string in the conduit to pull the ethernet wire. Hopefully it's not rotten and will take the stress of pulling the new wire through. Years ago I enjoyed the challenge of doing something like this. Now that I'm in my mid 70s it's more work than play, once I get on my knees .... it's hard to get back up standing. :-( Yeah, boo hoo, whoa is me ..... getting old sucks but it beats the alternative. One of my favorite quotes: "The spirit never ages, it's the body that ages, failing the spirit" George Harrison.
Orbi135Ward
May 18, 2025Aspirant
- plemansMay 19, 2025Guru - Experienced User
An ethernet wire IS the best option if you have it. Might try pulling a newer chalk/nylon string though with that old chalk line before pulling heavier wire :) Might save you some cursing. I have seen someone use a vacuum to suck a new line through a conduit before if you run into issues with the old line.
But again, if you've got the wire, an awesome option. Just make sure it isn't further than 300 ft. Thats all ethernet is rated for.
