rodathome's avatar
rodathome
Follower
Jul 12, 2017
Is this thing DoA ?
Just bought this today for my daughter.
Power light comes on ! That's good.
Plugged in lees than 6 inches from router.The WPS/Mode LED is out.
Pressed WPS/Mode button for >5 seconds, it flashes green and power light goes amber, and when power goes green, the WPS/Mode LED goes out
Pressed WPS/Mode button for <5 seconds, it flashes green (for about 2-3 minutes), the power light stays green, but then the WPS/Mode LED goes out again.
I've tried this on 3 different routers in 2 houses - so cannot progress past page 1 of instruction manual. Should I return it to the shop ?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello rodathome
    Have you tried to manually config the extender?
    DarrenM
