zambrelune
Jan 26, 2025Tutor
Issue setting up my netgear extender (ac1750 ex6250v2) and my netgear nighthawk M2 mobile 4G routeur
Hello,
I have since 2 years a mobile mobile 4G LTE Mobile Routeur M2( MR2100) that works correctly but does not have a long range.
I have recently bought a netgear extender AC1750 Wifi Mesh Extender that I would like to use to extend the MR2100 4G LTE Mobile routeur when at home.
It does not work.
The nighthawk app just block
I was able to configure it manually, the wifi ID of the MR2100 is identified and setup seems to go ok .. .
I am able to connect to the extender site and tried various configuration ( with or without mesh using same or different WIFI network id.
The connection client PC (or phone) to extender generally works ( even if sometimes it took few tries)
BUT : the connection between the extender or the router generally does not work ( it is in in grey and the corresponding led is off ).
Only once (by restarting both the extender and the router that I had put close to one another) they were able to connect together. But after 5 or 10minutes it went off.. and the connection was lost . I never repeated this very small success again.
I tried the extender with another modem ( my fiber box) and it works well with it. It just not do work for the MR2100 which is an issue because I bought it specifically for it ?
Apparently I tested to late to benefit from netgear technical support.
Do I need to change some configuration on the MR2100?
Did I do something wrong (but the setup is quite straightforward and I do not see what I could have done wrong)
Any suggestion is welcome
Regards
are you hardwiring the EX6250 into the M2 and setting the extender up in access point mode?
thats what I'd do.
the M2 is a mobile hotspot and the fcc limits its broadcast power significantly since it travels around. You might find that the extender provides plenty of coverage on its own.
Thanks for the suggestion, I'll try that.
Regards
Serge
I hope it works well for you!
