Gandhisflip's avatar
Gandhisflip
Follower
Aug 14, 2020
Issues with Netgear ex2700 and Vodafone router
Hi there
I've had real problems getting this to work - my Netgear range have worked with Sky / EE and BT routers in past.
So finally completed a hard reset and now have the Vodafone EXT visible as a connection option but not able to connect with any device. Can someone please advise?
Stuart
1 Reply
  • plemans's avatar
    Did you set it up via the wps method or using the installation assistant?
    What vodafone router is it?
