markmk's avatar
markmk
Follower
Jul 13, 2018
Just installed the EX7500, No 2.4ghz or 5ghz Led light?
I am not sure if the lights need to be on to say it's working on my EX7500. It is now plugged into the wall upstairs, I have 3 solid blue lights on, but the 2.4 and 5GHZ are not lighting up, is that ok? I am not sure if they need to be on or not to say it has a connection. The signal on my PC said it is 86% and the wifi is full (all the bars are on). I bought this to help my Nest Cam IQ stop disconnecting. Thanks for any info. Mark
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    If the unit it is working no need to worry about the lights.
    DarrenM
