Ocin400
Mar 07, 2017Aspirant
Keep getting multiple ext on network centre and not sure why or how to fix
Keep getting ext 3 0n computer but not on printer that always connects to ext so how do I fix
Ocin400
Mar 09, 2017Aspirant
Hi Darren
basically i I keep getting ext 2 ext 3 on devices in room where I need to connect over net gear extender but computer will connect to ext 2 but printer will not and vice versa I have found out on another forum how to delete unwanted network connections and also how to merge so iam thinking of trying to set up fresh and merge the exsisting base connection 2/5 signal strength with the boosted connection 5/5 signal strength and then hopefully both devices will connect to one network and all will hopefully work correctly
DarrenM
Mar 10, 2017Sr. NETGEAR Moderator
Hello Ocin400
Most printers are 2.4ghz wireless connections did you make sure that your extender is not 5ghz only.
DarrenM
