Edwarduk
May 28, 2017Aspirant
LAN passthough on Netgear PR2000 (Trek N300)
How do I enable my Netgear device to allow my existing LAN to be passed through to all connected devices - that is the Netgear to be transparent to all connected devices? I have Netgear Trek N300...
DarrenM
Jun 08, 2017Sr. NETGEAR Moderator
Hello Edwarduk
In the PR2000 have you gone to the WAN settings and unchecked the DHCP box?
DarrenM
- EdwardukJun 08, 2017Aspirant
Hi DarrenM
Thanks for responding to my post. Much appreciated.
Yep, as mentioned, when I disable DHCP on the PR2000 it 'falls over'. Specifically I get zero connection.
I don't know what my next steps are now - other than simply to bin the PR2000.
cheers
Edward
