scintu
Jun 07, 2017Aspirant
Lan Printer
Hi i bought the range extender, i want to connect a printer at the router, but the router is too far, so i bought a range extender where i want to connect the printer with a lan cable to the wifi ra...
- Jun 08, 2017
A range extender works by bridging two SSIDs together: the main SSID broadcast by your router and the extender's own SSID. It also works by bridges its Ethernet port to the main SSID. Since you will be connecting your printer to the extender with Ethernet, the extender's own SSID is irrelevant as far as the printer is concerned. You can connect other wireless devices to the extender's SSID. They will behave as if they are connected to the main SSID.
scintu
thanks for your reply, i will try, also if different ssid will work?
TheEther
Jun 08, 2017Guru
- scintuJun 08, 2017Aspirant
ok, but if i connect the printer at the main router it works, but connecting to the wifi range extender through tha lan cable does not work!
