vb's avatar
vb
Link rate light is red on WN3000V1 range extender
Link rate light on my WN3000 V1 range extender is red, but connection to router and internet is working.  I don't mind the red light as long as it is working but wonder if this means some problem is developing in the future.
  • If you are referring to the right most light (router link light), red means poor connection to the main router.
    • vb's avatar
      vb
      Yes, i understand I have a poor connection, but the devices (TV, iPad) seem to work fine.  Should I just ignore it?
      • Daenerys's avatar
        Daenerys
        Luminary
        Yes, you may just ignore it. Should you encounter connectivity issues, relocate the extender or the router to rule out interference,
