Tsar_maximilian
Oct 02, 2025Aspirant
Linking mismatch with two EX80 nighthawks
I have 2 nighthawks, one is Ethernet connected to the router and the other is linked to the connected AX6000 nighthawk via an Ethernet cable. Essentially they are daisy chained to each other.
Oct 03, 2025Guru - Experienced User
Tsar_maximilian wrote:I don’t know the answer to this but surely Ethernet cable doesn’t require a distance ?
The maximum distance is 100m (~328 feet). But I think FURRYe38 is focused on the wifi performance.
Tsar_maximilian wrote:I don’t know what AP mode is so I guess no
AX6000 is a speed rating, so it doesn't clearly identify what you have.
Do you have two EAX80s (which is an Nighthawk extender), or do you have two RAX120s (which is a Nighthawk router)? Both are labeled as AX6000.
If you have the routers they should be in AP (access point) mode - which is setting them up to run as extenders.
Tsar_maximilian
Oct 03, 2025Aspirant
I have the EAX80’s
