Tsar_maximilian
Oct 02, 2025Aspirant
Linking mismatch with two EX80 nighthawks
I have 2 nighthawks, one is Ethernet connected to the router and the other is linked to the connected AX6000 nighthawk via an Ethernet cable. Essentially they are daisy chained to each other.
Tsar_maximilian
Oct 11, 2025Aspirant
Thanks everyone for the help, I believe this is the fix and I have managed to get one of the EX80’s in AP mode! However the other one is stuck in bloody router mode. No matter what I do to reset. It refuses to launch in NETGEAR_EXT mode for me to set it up
Oct 12, 2025Guru - Experienced User
EAX80 only has AP or Extender mode. There is no router mode.
Press the reset button on the other EAX80 for 15 seconds then release. Give about 2 minutes then look for the wifi signal or set it up using a wired PC.
- Tsar_maximilianOct 13, 2025Aspirant
Hey! I reset the extender a million times with the instructions about, unfortunately though it goes to 'NETGEAR' and wont let me connect through wired or wireless. Im not sure too much about the wired connection step though. Mainly because when I put the ethernet cable into the extender it refuses connection unless it is tethered to the main router.
