bflowe
Sep 26, 2018Aspirant
linking netgear extender to technicolor router
My service provider has given me a free technicolor tg589 router to replace my old existing netgear router. i have been using a wn3000 RP range extender which has worked with the Netgear router for a...
Sep 26, 2018Guru - Experienced User
I suggest resetting it again, and set it up without pressing the WPS button on the extender.
You'd join the _ext network (which should be open), and then browse to mywifiext.net and complete the setup. You can enter the client network's passphrase yourself, and not depend on WPS setting it correctly.
bflowe
Oct 19, 2018Aspirant
Thank you. That has worked
