cireland
Sep 16, 2018Aspirant
Literally no upload speed on wired AC3000-Nighthawk X6S Tri-Band WiFi Mesh Extender
Hi, So I am having issue with the extender actually have been for ages with constant disconnects , anyhow that is not the main problem (which I think I fixed by going back to default fi...
cireland
Sep 17, 2018Aspirant
Sorry, I should have been clearer when I say wired I meant connected via ethernet to the PC.
So EX8000 is connected via my router via wifi and then I connect the EX8000 via ethernet to my PC.
Sep 17, 2018Guru - Experienced User
Ok, that helps.
Are you using FastLane?
When you connect the PC and phone with WiFi are you using 2.4 Ghz or 5 Ghz?
Are you using MAC access controls in the router?.
This could be a cabling issue, or a switch port issue. Have you tried using a different ethernet cable, or a different LAN port in the EX8000?
- cirelandSep 17, 2018Aspirant
Sorry for the delay I wanted to get home and check a couple of your points to make sure.
Are you using FastLane? - I don't think so I can't actually see having gone through all the options anything called "FastLane"
When you connect the PC and phone with WiFi are you using 2.4 Ghz or 5 Ghz? Phone I connect with either it picks up the strongest signal. For some reason the PC doesn't find the 5Ghz so only the 2.4Ghz
Are you using MAC access controls in the router?. Not sure what this is - I have full admin if that is what MAC access kind of means..
This could be a cabling issue, or a switch port issue. Have you tried using a different ethernet cable, or a different LAN port in the EX8000? Yes tried a different cable and ports. I thought it could be a cable issue or a port issue but given that the download works as it should, the upload should equally work?
- StephenBSep 18, 2018Guru - Experienced User
Your user manual is here btw: http://www.downloads.netgear.com/files/GDC/EX8000/EX8000_UM_EN.pdf
The datasheet is here: https://www.netgear.com/images/datasheet/networking/WiFiRangeExtenders/EX8000.pdf
Actually, per the datasheet it is automatically enabled. Is the "maximum throughput" LED on the extender lit white (not blinking).
Does the PC WiFi card support 5 Ghz?
Then you aren't using them. The extender also has MAC access controls, you can look at page 29 in the manual if you want to get a sense of what they are for. But for now, it's good that you aren't using them, as they could be part of the puzzle.
That depends on the cable/port issue. Transmit and Receive data use different wires in the cable (and different pins in the NIC socket). So a problem on that affects only the transmit wires might not effect the receive data (and vice versa).
But if you've already tried a different cable and a different port, I think we can rule that out.
I'm not seeing anything wrong in your configuration pictures, so I am a bit puzzled on what might be going on.
Can you check your PC ethernet status, and confirm that it is using 1 gpbs full duplex? Also, try pinging the router's internal IP address, and see if that responds.
- cirelandSep 18, 2018Aspirant
Thanks for your help it has been much apprichated. However I decided to check the drivers for my motherboard and I begun to think it was something software related and there was an update on the 14th Sept (when the upload speed crashed) installing the new drivers has fixed the problem!
Thanks again.
Thought some pictures might be helpful.
https://ibb.co/jKOuPz
https://ibb.co/mN414z1 - EX800 2 4ghz Wi Fi
2 - EX800 Ethernet
3 - Virgin Media Router (wifi)
4 and 5 are EX800 settings.
Appreciate your help.
