Randomisation21
Sep 05, 2019Aspirant
Log In Details
I have to reconfigure the Netgear settings as noe I have a new router and typical in these situations the staff member who set up the network no longer works for this organisation
What isthe easiest way to get access to the settings?
I believe we have a WN3000RP
I have a username and a password burt have no idea how to log on and where to log on!
Your help much appreciated
Many Thanks
John
jhellier@inthemixproject.org.uk
- Christian_RNETGEAR Employee Retired
Randomisation21,
Browse to www.mywifiext.net using a wireless device that is connected to the extender's WiFi network and enter the credentials there to configure the extender.
~Christian- Randomisation21AspirantThank you Christian appreciate your response the only issue we have is we don’t really have IT specialist with this now has as the set up wax awhile ago and I can’t quite see what I need to do is there any net gear support team I could ring when I’m actually connected in the office to see if I can get some help ? They way the WiFi is plugged in at the moment means i Router is plugged into a lan socket It’s loops via a distribution cabinet that plugs in Apple Time Capsule which we need to have on the network and then back out into the room and the fact and we think that’s what I was in the dropouts as it’s having to work too hard I know that the EE signal into the building iso the wiring could be causing me a slowing and dropouts
Randomisation21 - I have sent you a message. Please respond at your earliest convenience.
Christian
