hbio01's avatar
hbio01
lost of Wifi networks extension
Hi
At least every day I lose both of my wifi extended networks (2.4GHz and 5Ghz) and I have to reboot my EX6200 repeater to recover; Then it works fine.
Both of the networks are labeled xxxx_2GEXT and _5GEXT. Once rebooted, performances are OK.
The lastest firmware is installed (V1.0.3.74_1.1.109).
I hope you will have a tip for me.
Kind Regard.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello hbio01
    Have you tried to adjust the wireless channel on your main router to improve the wireless signal in your home and to help with wifi interference.
    DarrenM
    • hbio01's avatar
      hbio01
      Hi,
      Here are the WiFi channels configuration for both of my equipments (Box/Router & EX6200). Have you any idea ?
      Kr
      Network Power (dBm) Channel Security Type Mode Network Address MAC
      HBI-5Ghz 36 + 40 + 44 + 48WPA2-PSK [AES]Managed802.11n/acMon modem
      HBI-24 6WPA2-PSK [AES]Managed802.11nMon modem
      HBI-24_2GEXT-57 dBm6WPA2-PSK AES-CCMPManaged802.11nc0:ff:d4:83:48:f1
      HBI-5Ghz_5GEXT                     -73 dBm36WPA2-PSK AES-CCMP            Managed802.11nc2:ff:d4:83:48:f1
