gwsmick
Oct 31, 2018Aspirant
Lost router connection
Had everything all setup and all green lights. Now all lights are green except the router light, which is blank. What has happened?
gwsmick
No, I have not tried browsing to www.mywifiext.net. Didn't need to do that at the original setup. Worked great for about a week and then lost the router connection, and cannot get it back.
Nov 01, 2018Guru - Experienced User
Well, try it now. If my.wifiext.net shows no wifi connection to your router, then you can try re-joining the router network from the web ui.
