Devoratrix's avatar
Devoratrix
Low internet speed on PLW1000v2 Extender
Hello,
I recently got PLW1000v2. Connected it to my modem with cat6 LAN cable. And the other device with antennas is plugged in a room right next to it. Everything is working properly. Connection is solid. But... The speed, looks like it's capped at 75mbps. No matter if it's a cable or WiFi. Both speeds I get are max 75mbps. My main internet speed is 600mbps which I usually get when connecting directly to my modem, without the extander. But when I connect to the extender the speed is somhow capped at 75mbps. Both devices are plugged in directly to sockets in the wall. I've updated the firmware, but it changed nothing. Tried changing cables and ports, but everything is working fine. In the device settings there's no such thing as "Cap at 75mbps". Device's settings say that Wireless mode is set to "up to 433~mbps" (5ghz). But I can't get even that. What Am I doing wrong ?
  • plemans's avatar
    what are you doing wrong? Nothing. It can be mulitple issues.
    Many people see outlets next to each other or just 1 room over and think "they're close to each other, they should work great". When many times, those outlets have quite a bit of wiring between them because they might be on different circuit breakers. so they might be within 10ft of each other but have 100+ft of wiring in between them. When they're on the same circuit, their performance is quite amazing but add a circuit inbetween them, and performance drops off quite a bit.
    also, many things can interfere with powerline. Such as:
    high draw appliances
    Old/bad/poorly done wiring
    gfci outlets
    arc fault outlets
    surge protectors
    electronics going bad
    cheap cell phone chargers
    distance
    Poorly made electronics
    This can all inject interference in the powerline system.
    There's also a misunderstanding in performance. Powerline numbers are over inflated more than wireless and thats already pretty bad.
    I'd take a read through actual testing on the PL1200. Its a step up from yours but should give you some actual performance data to go off that is pretty reliable.
    https://www.smallnetbuilder.com/lanwan/lanwan-reviews/32717-netgear-pl1200-powerline-1200-reviewed
    • Devoratrix's avatar
      Devoratrix
      Well, then I might look into my powerline more closely. I'll test more with other electronics plugged out. Because there are a few things working on the same circuit. Thank you for your help. If I don't forget, I'll post if it worked.
